Steve & Nancy Riffe
Date:  12-30-2013
Number of Hours:  0.50
Brief Description:  Prep to Bleed Brakes
In prep for bleeding brakes, thought I’d better see if my lines had a good seal before filling with fluid and possibly having leaks inside the fuse. I rigged up a T fitting for a pressure gauge and Schrader valve that I could tie into the brake system. I did not connect the lines to the reservoir, but capped the ends instead. I wanted to check each side independently--in case of a leak, may be easier to isolate. I started on the left side (closest to my heater!). I disconnected the line to the brake caliper and attached it to the T fitting. Got it all hooked up and added about 8 psi air—hmm, slowly bled down. Figured it would leak somewhere. Tomorrow night I’ll get some soapy water and start the leak hunt.
Ready for some air pressure
Plumbing for leak check
