Dug thru the parts bin in search of something to work on while waiting for a hoist. Found the F824B inspection plates that cover access areas on the fuselage under the HS. Peeled off the blue plastic and edge finished on the scotchbrite wheel. Then I drilled out the pilot holes to #28 and used the pneumatic squeezer to dimple for #6 screws. Scuffed up with a scotchbrite pad, cleaned with dawn soap then shot on a coat of NAPA 7220 primer.
