Steve & Nancy Riffe
Date:  12-7-2012
Number of Hours:  1.00
Brief Description:  Rear control cover-4
I filed and smoothed the edges of the cover, scuffed, cleaned and primered. I also cut off the vent mount that was part of the right seatbelt anchor. After it was removed and filed smooth, I decided it needed some primer—at this point I realized I had not primered the seat belt anchors that protrude above the floor. Taped off everything I didn’t want to primer and sprayed the belt anchors. While the floor was out, I also blew a cotton ball with string thru the conduit previously installed in the floor.
Hooked up the scat tube--the GIB will have air!
Cover & seat belt anchors primered
