Steve & Nancy Riffe
Date:  10-2-2012
Number of Hours:  1.00
Brief Description:  Rudder cable fairings-1
Moved to the back end of the fuse and started on the rudder cable fairings. I ordered these fairings from Avery sometime back and now looks to be a good time to install them. Started on the left side and drew some lines on the fuse so I could spot where to position the fairing. Trimmed the fairing so it was not so blunt on the front end. Laid out rivet holes and drilled the fairing to #41. Held the fairing in place and match drilled to the fuselage, clecoing each hole as I moved along. Moved to the right side and trimmed the fairing to shape, laid out rivet holes and drilled to #41.
Left side trimmed
Left side trimmed
After match drilling
Fairing clecoed in place
