Steve & Nancy Riffe
Date:  9-19-2012
Number of Hours:  1.00
Brief Description:  Rudder pedal extensions
Ordered a plunger lock from McMaster Carr to lock the brake valve arm in either an open or closed position—probably won’t be here for several more days. A popular and possibly a much needed mod are the rudder pedal extensions. I had earlier purchased a set from Romeo-Victor. Pulled them out of the parts bin tonight—nice workmanship. I laid out 3 mounting holes on the rudder pedals and drilled them to #30. I next clamped the extensions to the pedals and match drilled to #30, and finally to #19. Machine countersunk and bolted them together. Need to polish up the edges just a bit and call it good.
Match drilled the pedals to extensions
C/S pedals, left one bolted together
