Attached the legs with castors to the false spars. Then I removed the fuselage from the rotisserie. Couldn’t round up any help for this, so I had to man-handle the beast into submission. I pulled the fuse out of my shop, turned it around and pulled it back in. Set the false spars on jackstands—seems very stable. Retrieved the aft deck and wiped off several months of dust. Pulled the blue vinyl from the inside of the skin and began clecoing to the fuselage. Several months back when working on the deck, I used an Avery edge roller and put a slight bend along the sides of the deck—left a nice tapered edge where the deck meets the fuse skin.
Removed fuse from rotisserie
Climbed inside to attach shoulder harness attachments
