Steve & Nancy Riffe
Date:  4-15-2012
Number of Hours:  1.00
Brief Description:  Finish Xponder wiring, started coax for ELT anten
Finished the transponder coax run and added a TNC connector to the end of the coax. Used some self fusing tape for strain relief on the cable/connector. Drilled a hole for a snap bushing to pass the snakeskin bundle thru the bulkhead heading toward the front. Next I made up the ELT cable—added a BNC connector to one end. Not sure what to put on the other end yet, but I’m thinking some sort of bulkhead connector—need more research on this.
Antenna and wire bundle--waiting for the xponder
Wire run for xponder
