Brief Description: Battery terminal, pitch servo wire run
Received some large shrink tubing today. Cut a piece and shrunk it over the end of the #2 battery cable-firewall end. Strung the cable back thru all the snap bushings in bulkheads back to the battery location area. Still need a firewall passthru before I cinch down all the adel clamps. Drilled for a couple of snap bushings in bulkheads on the right side of the fuse for pitch trim wires. Also with the shrink tubing, I received some “snake skin” which I used for the pitch servo wiring. Tried pushing the wires thru, but could only get about 2 feet before it hung up. So, I pushed the snake skin over some ¼” tubing (future fuel vent lines, I think). When I got to the end, I taped the wires to the tubing and pulled it back thru. Then ran the wire bundle from the servo area to the front. Will have several feet to cut off, but will wait until the Skyview is mounted before any cutting.
