Steve & Nancy Riffe
Date:  3-30-2012
Number of Hours:  0.50
Brief Description:  Xponder antenna doubler-finish
Dimpled the mounting with the pneumatic squeezer and dimpled the fuse skin with a pop rivet tool-which does not give as crisp a dimple, so I lightly countersunk the skin by hand turning the deburring bit in each hole. Cleaned up the doubler and shot with primer. After it dried, Nancy helped me rivet the doubler to the skin. We practiced on some scrap then jumped to the fuse. She got the hang of it quickly and did a great job with the gun. Out of the 16 rivets, only drilled out and replaced 4 (probably the buckers fault!)
Doubler riveted to fuse
