After much head scratching, finally decided on location for transponder antenna. I had previously made a doubler from some .040 stock. Taped the doubler in position and match drilled to fuselage, clecoing each hole as I went. Final reamed the two mounting holes to 3/16” and used a step drill to open up center hole to 9/16”.
