Steve & Nancy Riffe
Date:  3-25-2012
Number of Hours:  1.00
Brief Description:  Wiring pitch servo, xponder antenna
I installed some D-Sub pins to the ends of the pitch servo cable. Used a crimper from Stein to crimp the pins to the wires. Applied some shrink tubing and then inserted the pins into the shell. Checked everything for continuity to make certain I had a decent crimp. Forgot to take a pic until I was done with inserting the pins—most of you have seen it before on other logs. I will order some “snakeskin” to put these wires in, and then run everything forward. Next, I laid out a doubler on some .040 for the transponder antenna. I have a location picked for the antenna, but want to check with the knowledgeable bunch on VAF before cutting into the fuse bottom skin.
Wiring to connect to pitch servo
Doubler for Xponder antenna mount
Possible location for antenna
