Formed the line from the fuel valve to the filter. I used a wire to get the approximate length and bends, then started with the tubing. Used the Imperial bender to get a nice bend coming from the valve and cut the other end to length plus an inch. Inserted the fuel line and adjusted the bend coming from the valve until the alignment was right—actually did this at least 4 times. Removed again, slipped on the nut and collar and flared the tube. Inserted the tube once again and connected to the valve. Marked the other end, bent in place, disconnected the line from the valve, then cut the other end where marked. Slipped on the nut and collar and flared the line. Connected the line to the valve and the filter—looks good. Still need to fab a line from the pump to the firewall as soon as I receive some more tubing.
