Received my Imperial tubing bender a few days ago, so I thought I’d have a go at the fuel lines. Started on the line from the left tank to the fuel valve. Bent a piece of wire until I thought I had the shape figured out. Read and re-read the instructions that came with the bender and began bending. It came out close enough to actually be useable. Prepared to flare the end of the line—don’t forget the b nut! Slipped the fitting on the line, then the b nut and flared the tube. Nice flare. ACKKK—I put the b nut on backwards! Cut the flare off, but now the line is too short to work. Started over, this time it all came out good. Began planning the line from the right side-looks to be a bit more challangeing.
