Steve & Nancy Riffe
Date:  3-1-2012
Number of Hours:  1.00
Brief Description:  Pitot & AOA Lines
Ran lines for AOA and Pitot tonight. Started at the rear of the fuselage where the ADHARS will be mounted and headed toward the front. Ran both lines beneath the floor similar to the static line run. Used 2 adel clamps at same location to secure both lines, secured both lines with a couple of tie wraps and used snap bushings thru the bulkheads. “Adel” is fast becoming a four letter word in my shop. They sure work good, but it’s a challenge to get them installed.—
AOA & Pitot end where ADHARS will be mounted
Lines headed to the front
AOA will end before main spar web, pitot will
AOA will end before main spar web, pitot will "T" at wing
