After several evenings of getting nothing done except looking at the fuselage, I finally got it in my head how I wanted to run the SafeAir lines. I decided to run the static line on the right side of the fuselage, going under the floors. Installed one adel clamp and tied the static line into the loop that connects the 2 static ports, then used a step drill to cut a 3/8” hole for a snap bushing in the F808 bulkhead. The other side of the loop will also have a T fitting for a short run to the ADHARS unit.
Static line-thru bulkhead, runs behind ELT mount
Static line T's-1 for ADHARS and 1 for instruments
