Steve & Nancy Riffe
Date:  2-13-2012
Number of Hours:  1.00
Brief Description:  Primed interior-1
Temps finally up enough to shoot some primer in the interior. Went thru one can of NAPA 7220 primer—after the can was empty and the primer was dry, I found a couple of areas that are a bit light on primer—would rather be on the light side than deal with a bunch of runs. The second coat (hopefully tomorrow evening) should finish up the interior. So far I’m pleased with the way it’s turning out. Note: area on bulkhead behind instrument panel will be cut out for access door--no need for primer here.
Interior-forward shot
Interior-looking aft
