Installed the F8119A mounting plate and ran the cable to the F8111 mounting bracket. Secured the cable to the F8119c anchor bracket. Installed the adel clamps and checked operation. The wire inside the cable was about an inch too long, so I unclamped from the anchor bracket and cut it off with the dremel wheel. Re-installed everything and checked operation—think I’m going to call the aileron trim DONE! Well, almost—need to add a couple of cotter pins and nylon locknuts, but will do that later. Will remove the trim system during wiring phase.
