Steve & Nancy Riffe
Date:  12-31-2011
Number of Hours:  1.50
Brief Description:  Forward Baggage Door-5
Finished deburring all of the baggage door parts. Scuffed up all the parts, then dimpled most of the #40 holes with the pneumatic squeezer. There was one hole in the outer door skin above the latch attachment that I had to use the DRDT-2 dimpler to reach. Had to be very careful using the pneumatic squeezer on the F873B & C ribs. The yoke and female dimple die just fit on the inside of the rib, so took a very very slow squeeze to insure the male dimple die fit into the intended hole—would be very easy to punch a new hole in the ribs. Machine countersunk the #40 holes in the F873F angle. Dimpled the #30 holes in the outboard flange of the F873D inner door skin and the F873E rib. Cleaned with MEK, Dawn soap and MEK again. Shot everything with NAPA 7220 primer.
Countersinking the F873F angle
Close fit-better line up that hole!
Primed all of the baggage door parts
