Pulled parts for the front top skin attachment and baggage door from the shipping box—which is now almost empty—only a few pieces left. I suppose that means that the fuselage structure is nearing finish. Removed vinyl and finished the edges of the F821B1 and F821C1 baggage door support strips. Used the dremel with cutoff wheel to remove the sections from the F821 top skin—then edge finished the skin. Clecoed the support strips and the top skin to the instrument sub-panel attachment, the forward baggage bulkhead and the firewall assembly. The .032 skin gets rather stiff by the time you work your way down to the longerons.
