Screwed the F803 instrument panel to the left & right F803B sub-panels. Dropped it down 1 screw hole for access to the rivets across the top. Riveted the F803C to the sub-panels using the squeezer. Left the center 8 holes open for any minor adjustments when fitting the top forward skin. I have 2 rivets that set slightly proud that I will drill out next session and set again. Still need to rivet the left & right clips to the sub-panels. This was a really fun “mini” project.
