Brief Description: Aft top skin/rear bulkhead-final
Cleaned up the F810 bulkhead and the ADAHRS mounting angles with MEK, washed with Dawn, another wipe down with MEK and then shot with NAPA 7220 primer. Also primed the rivet lines on the inside of the aft skin. After the primer dried, I riveted the F810 bulkhead to the fuse. Used the pneumatic squeezer (my favorite tool) on all except the outer most rivet on each sideāhad to drag out the gun to shoot and buck these two.
