Steve & Nancy Riffe
Date:  12-8-2011
Number of Hours:  1.50
Brief Description:  Aft top skin/rear bulkhead-1
Tonight I removed the left elevator and the HS. Wow, much more room in the shop now. Clecoed the aft top skin back on. I had not match drilled the skin to the F810 bulkhead because of interference with the HS. Many earlier logs reported a gap between the skin and the bulkhead. I thought that maybe Van’s had fixed this in the later kits--silly me! I had a gap just like everyone else. I cut a strip of .025 to fit between the skin and bulkhead for the last 3 rivet holes. Still needed an .063 spacer for the last hole, but will have to taper the upper end just a bit for smoother fit. Now, need to repeat for other side.
HS moved from the fuse back to the wall
Yikes--gotta gap that needs a spacer
Gap filled with spacers
