Steve & Nancy Riffe
Date:  11-7-2011
Number of Hours:  1.00
Brief Description:  Instrument Panel-1
I'm skipping around in the manual a bit, but everything has to get done at some point, so tonight I started on the instrument panel. Dug out all the parts and studied the plans. Used the dremel with a cutoff wheel to separate the F803D left and right clips from the F803C panel attach flange. Attached the F803A instrument panel to the left & right subpanels—offset the panel one screw hole lower so as to provide clearance when clecoing the attach flange to the subpanels. Clecoed the attach flange to the subpanels and installed the assembly into the fuselage. Match reamed #41 the fuse to the F803 left & right clips. Removed the assembly, deburred and dimpled the holes in the fuse. Had to use the pop rivet dimple tool for this—doesn’t make a real crisp dimple, so I lightly counter sunk the holes also. Match reamed #41 the F803B sub-panels, the F803D clips and the F803C attach flange.
Panel test fit to fuse
Match reaming flange to sub-panels
