With all the Halloween goblins banging on the door, I didn’t seem to get much done in the shop tonight. I started on the flap motor install. Drilled all the required holes undersized then reamed up to either #12 or ¼” as called out on the plans. Next up is to drill a 1/16” hole in the flap motor housing for a safety wire. Not sure how this is going to work yet—will have to ponder this next step a bit.
