Steve & Nancy Riffe
Date:  8-28-2011
Number of Hours:  1.00
Brief Description:  HS Mounting-1
Spent some time cleaning up and re-arranging the shop. Nancy helped me remove the fuse from the rotisserie and place onto jackstands. Began the process of leveling the fuse—was able to get it leveled laterally without issue. Initial check shows level front and back-therefore I can assume there is no twist in the fuse—yeah! More leveling to come prior to getting the HS off the wall. I want to study the mounting process a bit more as well as reviewing some of the other builder’s logs. I did separate the F885 spacers and smoothed the edges on the scotchbrite wheel.
Beginning to level fuse.
F885 spacer separated & edge finished
