Steve & Nancy Riffe
Date:  8-22-2011
Number of Hours:  1.50
Brief Description:  Andair Fuel Valve-2
More fuel valve mounting. I got the front angle drill drilled up to #30 and the rear angle drilled up to #19. Also got the holes drilled in the rear angle to mount the fuel valve. Had to use the right angle drill to get the holes in the aux. Longeron—I really don’t care for using the angle drill. Need to c/s for rivets in the front angle and screws in the back angle, add nut plates etc. Once again, deviation from plans sure adds to build time. Only got one pic tonight, will do better next session.
Fuel valve temporarily mounted
