Steve & Nancy Riffe
Date:  8-17-2011
Number of Hours:  0.80
Brief Description:  F635 bellcrank, control tubes
Riveted the F635 bellcrank together using the pneumatic squeezer. Measured and marked the length to cut the F841 and F840 per the plans. Used a tubing cutter to cut the F840—need to pick up a larger cutter for the F841. Used folded paper method to mark location of the eight holes in one end of the F841 and inserted the bearing cap.
F635 bellcrank riveted
Marking F841 for drilling
