Laid out holes to attach angle to mid cabin cover. Punched holes in the angle, then match drilled to cover. Mounted the cabin cover, attached the angle with clecoes. Laid out and punched holes in the upper part of the circuit breaker panel. Attached c/b panel to the angle with clecoes,then drilled thru the panel into the console. Next up-drill for nutplates, then primer.
