Received .025 aluminum sheet yesterday, but had a trip and got back sorta late-about all I did was open the box. Tonight I traced my template for the c/b panel onto the sheet and cut it out. Then I cut out a strip and used a brake to form an angle which I will rivet to the mid cabin cover and install nutplates to attach the c/b panel. Laid out and drilled the holes in the angle for the nutplates, then match drilled to the c/b panel.
