Finally! Finished deburring the rear seat back. Thought summer might be over before I finished this job. Anyhow, I’m nearly ready for primer. However, I’m not real sure I have the orientation of the hinge done correctly. The drawing was rather confusing –but it appears that I may have to cut another piece of hinge, and redrill the holes in the hinge. Will take a bit more study and research of other builders logs before I prime and rivet.
A zillion nooks & crannies to edge finish!
Deburring & edge finishing done
Is the eye on the end of the hinge turned up or down?
