Had time in the shop to bang out a dozen or so rivets. Found the -5 rivets with the fuselage hardware. Was able to use the squeezer to set a few rivets that could be accessed thru the inspection panel. Had to drill out one rivet that I only got half of the bar on—looked kinda ugly. I finally ran out of arm length. Need to get someone on the gun while I buck about 10 rivets on the rear spar.
Easy reach for the first 8 rivets--gets harder farther up
