Brief Description: RTV'd conduit, started R. fuel sender
Well I wasn’t quite finished with the conduit. I added some RTV silicon where the conduit passes thru each rib. I removed the aileron and then Nancy helped me move the wing from the cradle onto the table. I bent the float arm on the sender per the plans. Then I tightened the fuel pickup fitting and found one of the anti-rotation brackets that would fit over the nut. Van’s supplies several of the anti-rotation brackets which are “clocked” differently so that at least one will match the fuel pickup. Match drilled the bracket to the T-708 end plate with a 1/8” bit, then reamed to #30.
