Tonight I got everything ready to tackle the proseal. I scuffed up the T-708 end plate, fuel sender and mounting surface on the end rib. Then I laid out everything needed to proseal the sender, fuel pickup mount and access plate. I will use cherry max rivets to attach the anti-rotation bracket to the end plate. I picked up a 60cc syringe, some tongue depressors and another box of rubber gloves. Went thru a couple of dry runs to make sure I had the sequence firmly in mind. Discovered that I could not find my hex bit that fits the socket head screws—ack! Good thing this was for practice—will pick up another bit tomorrow.
