Whoo Hoo-UPS brought care packages today. Received senders, parts to fab the inspection hole for the stall warner and proseal from Van’s today. Also received a tube of fuel lube and some Boelube from Spruce. Started in on the fuel sender for the left tank. Checked the ohm resistance of both senders and found them within specs. Bent the float arm per the plans for the left tank. Interesting to note that the dimensions of the float arm length are different on each wing.
