Brief Description: Filled holes where stall warner would have gone
Nancy and I moved the left wing from the cradle onto the work table. My wing came with 7 holes near the leading edge for installation of Van’s stall warner. Since I am using the Dynon AOA, I elected not to use the stall warner. I notice that some builders are using the stall warner, while others are not. Kits prior to October or November 2010 did not have the provision for the stall warner, although it would not be difficult to retrofit. I lightly countersunk the seven holes with a deburr bit and drove some NAS1097AD3’s in each hole. Next I pulled the inspection plate from the end of the tank—smells like pro-seal in there! Should receive the senders in a few days.
