Worked on routing pitot tube/AOA lines. Had a tip from fellow builder (thanks Don!) to check out how another builder handled the line issue. Found some pics of a really neat method of keeping the SafeAir lines out of the aileron control arm (Jeff-thanks-great idea). I mostly just copied what Jeff had done and made a small bracket which I attached using the bolts in the aileron control arm bracket. This little bracket will keep the lines from getting either pinched or fouling the aileron controls. I may need to shorten the aluminum lines from the pitot tube in order to make a smooth transition of the SafeAIr lines into the pitot mast.
