I set the right wing aileron to “aileron neutral” using the tool I had previously made. Then I touched up a couple of areas with primer that had gotten scuffed while hanging the ailerons. Connected the long pushrods to the bellcranks. Using the ends of the long pushrods, I did several “aileron rolls”—worked out pretty well—now back to work. Got the flaps out and began reviewing plans.
