Brief Description: L. Wing Aleron brackets and gap seal
Had a productive day today--finished riveting the center aileron bracket, then moved to the outboard bracket. Shot and bucked the rivets thru the rear spar. Used the squeezer thru the end rib lightening hole to set the rivets on the end of the spar. CLecoed the gap fairing to the rear spar and skin. Squeezed the AN470AD4s to join the gap seal and rear spar. Next, I “double-dimpled” the gap seal and skin together and squeezed in the 470AD3’s. Nancy and I then moved the wing back to the cradle.
My serious "riveting" look! Camera timer was too fast!
