Drilled out the rivet from previous evening that needed to be replaced. Dimpled skin and gap seal together and squeezed in another rivet. Nancy and I moved the left wing from the cradle onto the table. Cleaned up the spar/skin area behind where the gap seal will be riveted on and shot a coat of primer. Clecoed on the center aileron bracket. Shot and bucked 6 of universal head rivets.
Primed spar/skin behind gap seal
Began riveting center bracket-note long rivet set on gun
