Brief Description: Inject primer inside W-818 pushrods
Injected some primer inside the W-818 pushrods to coat inside where primer was probably burned off when I had the ends welded on. After the primer cures, I will use some JB Weld to seal the 1/16” hole that I drilled in each tube for gas relief while welding. Also cut the spacers for the aileron brackets. Next, I built some “legs” with casters which I will bolt to the false spar that goes thru the fuselage. Need to be able to move the fuse around. Amazing how fast the shop can shrink, but this should help.
