Added another layer of glass to the outside of the right HS tip (to close the opening), and added a couple of strips of glass tape to the inside to reinforce the edges. With the left over epoxy, I added some micro to make a thick paste. I applied this mix to fill some low spots on the left elevator tip. Used some T-88 epoxy to bond the backing strip to the right elevator tip. Also added a piece of glass to the end of the elevator to close the opening. For some reason, I only got one pic tonight.
C/S glass-hole gauge shown
Backing strip bonded to right elevator tip with T-88
