I fit the tip to the right elevator and match drilled the holes. I offset the bottom trailing edge hole so as to not have interference with the hole on the opposite side. Removed the tip and match punched the tip and backing strip. Cleaned up and scuffed the backing strips for both elevator tip and HS tip. Shot a coat of primer on the side that will be exposed (other side gets bonded to the tip).
