Steve & Nancy Riffe
Date: 3-30-2013
Number of Hours: 2.00
Brief Description: HS TIps-5, VS & Rudder Tips-8
Within this fiberglass project, I have several areas that I’m working on at the same time. Last night I sanded the micro that I had applied to the rudder tip—it is beginning to get close to the height of the VS tip. Next, I removed the foam from the tip of the HS. Then I sanded the epoxy that had been applied to the aft side of the VS tip. Looks like the 3 coats of epoxy has filled all of the pin holes. Today I mixed up another batch of epoxy. Using a 1” wide brush, I “painted” on some epoxy to the seam where the rudder tip meets the rudder. After the area was “wetted”, I applied a layer of .003” thick glass strip (1” wide). I started at the front of the tip and pulled the glass down each side, brushing a little more epoxy on as I went. When I got to the aft end, I cut one side about ¼” short of the end and wrapped the other side around to meet the cut. Then I applied a layer of peel ply. Never done peel ply before--more experimenting on my experimental, I suppose. Next, I applied epoxy to the inside of the HS tip and layed in a second layer of glass. With the remaining epoxy, I added micro to make a very thick paste. I applied this to the glass on outside of the HS tip and then added a small amount to the top of the rudder tip—hopefully this will be the final coat to match the tip with the VS.
Final glob of micro added to tip
Thin glass layer with peel ply
Aft side of HS tip filled with micro
