Brief Description: R. Elevator-Rolled Leading Edge
R. Elevator-rolled the leading edge of the right elevator. Using vice grips, Nancy turned the pipe while I held the pipe against the skin and the work surface. Small end was easy, center section was not so much fun. Took lots of forming by hand to get the skins to lay smooth. The inboard end worked best of all. Drilled the outboard end and center section with #30 reamer, dipped the rivets in primer and “popped” them in. Still have to drill the inboard end and add pop rivets.
