Brief Description: L. Elevator-Rivet 606 rear spar
L. Elevator—Riveted the 606 spar to the skin. On the hinge side, had to grind down a flush die to fit under the hinge. Of the 8 holes (4 top and 4 bottom) at the end of the 606 spar, I was able to reach some of the rivets using a 4” no hole yoke. Had to use one pop rivet on the top side, and two on the bottom. Used pop rivets to attach the riblet to the skin.
