Brief Description: Trim Tab-Horn assembly, hinge alignment
Trim Tab-clecoed the 607 spar to the bottom of the 619 trim tab skin. Clamped the 717 to 718 (trim tab horns) together, then clecoed the 717 to the trim tab skin. Match drilled the 717 and 718 to the 619 skin. Marked line on the 721 hinge, then clamped the 721 hinge to the 607spar/619 skin. Still need to check alignment further before match drilling thru skin, spar and hinge.
