Brief Description: L. Elevator-Made Riblet-Debur Skeleton
L. Elevator—dug thru the spare parts to find my practice kit. Drilled out rivets for one of the ribs, measured approximate length needed and cut the rib to size. This little riblet seems to fit quite well in the elevator where the tabs were removed. Removed the skin from the skeleton—then removed ribs from spar. Began deburring the ribs and spar.
