Drilled (reamed) leading edge of rudder to #30 and installed AD-41-ABS blind rivets per plans. Did not end up with any gaps where the skins overlap. Not real impressed with the way the leading edge turned out, but darn glad to be done with it! Next I installed the rod end bolts. Done with the rudder-at last!
