Brief Description: Rudder-Fitting Skeleton Together
Good progress today! Finished trimming the 710 horn. Clecoed the bottom end of the skeleton together. Edge finished and fluted the 703 tip rib. Clecoed the rib to the 802 spar. Drilled the holes in the tip rib to spar to 1/8”. Next, I reamed the holes to #30, then removed the rib from the spar.
