Brief Description: HS-Drilled 405 to 810/814 angles
Removed 702 spar. Marked and drilled 405 rib for attachment to 810/814. Reassembled skeleton & skin. Drilled thru the 405, thru the 702 into the 810/814 angles. Measured edge distances and all look “good!”
